Adding Info to the .ads File
Old Jun 1, 2009 | 08:40 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Is there any way to add info to the ads file to let me know when I'm in AE and/or PE? If so, could you point me in the right direction?
I'm running 6E.
Old Jun 4, 2009 | 12:05 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Adding Info to the .ads File
I watch the "BL Cr Crt" when it is at 128 when you are in open loop, also PE (which is a non learning Closed loop).
I also look at the AFR, 14.7 in closed loop, non highway mode, in PE it is way less like 12.38.
I can't help on AE.
Old Jun 4, 2009 | 04:51 PM
Duts87ss's Avatar
Thanks, that at least gives me something extra to look at.
3rdgenparts
May 21, 2016 11:50 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
2012sergen11
Oct 13, 2015 07:38 PM
