my tunerpro can't find my autoprom
Old Jul 31, 2009 | 08:21 AM
slickfx3's Avatar
Car: 1989 Chevy Corvette
Engine: 383 SuperRam 10.7 AFR 195 220/229
Transmission: Fancy Smansy 87 Corvette 700r4
Axle/Gears: 3.33
sorry i searched, it works on my vista athlon x2 , but no on my xp celeron.
any clues???
the computer makes a ding dong sound when i plug it in and i tried the driver over and over again....
Comments? thanks again
Old Jul 31, 2009 | 06:11 PM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
Re: my tunerpro can't find my autoprom
What drivers are you using? The ones XP automatically installs or did you download htem off Moates? The ones on Moates work. The ones XP Autoinstalls don't work on some machines. Try the moates drivers. Also just double check your Autoprom switches. I have put mine in ALDL passthru before and couldn't get TP to see it until I flipped the switch back to Autoprom mode.
Old Jul 31, 2009 | 08:17 PM
slickfx3's Avatar
Axle/Gears: 3.33
thanks i'll try it, the drivers came with the cd and i unzip the manual drivers and those don't work either
i flipped the switches and that don't work but i'll do everything over again, thanks
Old Jul 31, 2009 | 10:26 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
These newer operating systems like to try and do everything for and can work against you at the same time.
The easiest way I find to make it work is to :
  • Plug in the AP to the USB port (ding)
  • Go to device manager and see what port it is connected to.
  • Open properties and change the port configuration "latency" to 1
  • save and exit.
  • Then go to TP and set the preferences to the same port
  • Set "Disable checksum by uploading "AA" to 0x ** during emulation if you will be emulating. IDK what setup you have for the correct address there.
should be able to connect at that point.
Setting the port speed to 115K has helped me on some laptops, not sure what the max speed it can handle but it will work there and then you can increase to see if it will go faster.
Old Jul 31, 2009 | 10:49 PM
slickfx3's Avatar
Axle/Gears: 3.33
  • save and exit.
thanks I copied and pasted your comments and will try it this coming week,
thanks again!
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Breazlan
Sep 25, 2015 11:20 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
rjcme
Sep 5, 2015 01:23 PM
