Idle goes Open Loop. Sometimes.
Old Aug 9, 2009 | 12:28 PM
shuanm's Avatar
Car: 84 Z28
Engine: Stealth Ram 355
Transmission: Borg/Warner T5 WC
I have a 350 with 730 ecm and stealth ram intake. I can drive the car and it will warm up and go to closed loop. As long as I have my foot on the gas it stays in closed loop, but when I let it idle for a few seconds it goes to open loop and then it starts to act crazy. Is my O2 sensor bad, or is something else going wrong?
Old Aug 9, 2009 | 02:54 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: Idle goes Open Loop. Sometimes.
Could be the O2, replace it with a heated one.
If you can scan the car its easier to see why its going out of CL.
Old Aug 9, 2009 | 10:19 PM
shuanm's Avatar
Car: 84 Z28
I have a datamaster log or two where it does it. I'm not sure how to post that though.
Old Aug 9, 2009 | 11:44 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Do you have a heated or non heated O2? How far from the head is it if its non heated?
Old Aug 10, 2009 | 06:54 AM
shuanm's Avatar
Car: 84 Z28
It's Non Heated, and it's in the header. It's a shorty where all of the tubes ome together.
Old Aug 10, 2009 | 11:22 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Its definatly cooling off causing it to go into OL.
Get a 3 or 4 wire heated unit and you'll be fine.
I run mine off the Fuel pump relay for the heater power.
Be sure to make the adjustment to the bin so the PW is corrected by battery power so any voltage drop caused by the heater does not influence the PW.
Address 8016, bit 6 should be un-checked in the $8D mask.
Prodigious
Oct 4, 2015 11:20 PM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
