Swapped to T5, engine wants to stall when I push the clutch in.
Old Aug 19, 2009 | 05:15 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I just swapped to a T5 and have been learning how to drive it on the fly. Once thing I notice is when I push in the clutch the RPMS drop so quickly that the needle dips well below idle and sometimes even stalls. I'm thinking throttle follower?
Also, what else, if anything, do I need to futz around with in the PROM when swapping to manual?
Old Aug 19, 2009 | 07:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Swapped to T5, engine wants to stall when I push the clutch in.
First make sure that the ECM isn't going into DFCO. If so then raise the RPM and/or MPH limits.
Other then that the throttle follower would need to be changed. Slow down the rate that the IAC closes down on a throttle lift. And add some TF minimum steps.
Be sure there is enough maximum TF steps to be effective.
RBob.
Old Aug 19, 2009 | 08:20 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
There may be an "automatic/manual" flag to set, depending on the mask you are using.
Old Aug 22, 2009 | 01:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
From what I've seen, there are more things in the chip between a stick and automatic chip than what we can change. The stalling when you push in the clutch is one of them.
Ideally you'll want to start with a 305 5-speed chip and modify it from there. The AXXD is the 90-92 305 TPI 5-speed chip I started with.
Old Aug 22, 2009 | 01:13 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
I forgot to mention i'm running the EBL.
RedLeader289
May 28, 2019 01:47 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Luigytico09
Oct 1, 2015 08:46 AM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
