transmission datastream OD
Old Sep 10, 2009 | 08:57 PM
whitelightnin92's Avatar
im running OD with a 4l60E ive been having alot of transmission issues, i didnt know if anyone had a good datastream with things like linepressure and trans temp. thanks
Old Sep 15, 2009 | 09:27 PM
Re: transmission datastream OD
no one has it? right now i have the one 93v8s10 gave me. but i need to be able to look at the line pressure. if anyone has the adresses that works too
Old Sep 16, 2009 | 12:27 PM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
There is one on Moates site.
https://www.moates.net/files/4)%20Da...20A217.ads.zip but it looks like it is mainly for Engine.
Also if that isn't it, you could look at the ALDL zip file up on Moates with all the ALDL description of the datastreams in it. You just need to find the correct one and then you could make your own ADS file.
https://www.moates.net/files/4)%20Da.../ALDLstuff.zip
I have one for the PCMs using the 80e but that might be different.
Old Sep 16, 2009 | 12:47 PM
skwayb's Avatar
Car: 93 GMC Typhoon
Transmission: 4L80e
Ok after looking at the ALDL.Zip file it looks like it could be one of the following ALDL streams of a combination of streams. Sometimes there is one for just the Engine and one for the just the Trans. Or it takes putting 2 streams together and then using 2 different commands to dump the ALDL for either Engine or Trans. wish GM would have just said what MASK uses what stream. I always get confused just going off ECM and Engine type when we are talking about masks trying to figure out which one to use.
So it might be one of these or these 2 together (1 for engine and 1 for Trans)
DATA STREAM A201
ENGINE USAGE: PCM-6 4L60E
L03 5.0L VIN = H 93 C,K,G
L05 5.7L VIN = K 93 C,K,G
L35 4.3L VIN = W 93 S,T,M,L
LB4 4.3L VIN = Z 93 G,M,L,S,T,C,K
DATA STREAM A204
TCM (TRANS) USAGE: PCM-6 4L60E
4.3L TBI LB4 (VIN=Z) 93
4.3L TBI L35 (VIN=W) 93
5.0L TBI L03 (VIN=H) 93
5.7L TBI L05 (VIN=K) 93
Or one of these or 2 together (1 for engine and 1 for Trans)
DATA STREAM A217
PCM-6 WITH 4L60E TRANSMISSION
ENGINE USAGE:
L03 5.0L 94 VIN = H C,K,G
L05 5.7L 94 VIN = K C,K,G
L35 4.3L 94 VIN = W S,T,M,L
LB4 4.3L 94 VIN = Z G,M,L,S,T,C,K
* L03 TBI 5.0L 95 VIN=H C,K,G
* L05 TBI 5.7L 95 VIN=K C,K,G
* L35 CPI 4.3L 95 VIN=W S,T,M,L
* LB4 TBI 4.3L 95 VIN=Z G,M,L,S,T,C,K
DATA STREAM A218
The 4L60E transmission can be used with the following engines
TCM USAGE:
L03 TBI 5.0L 94 VIN = H C,K,G
L05 TBI 5.7L 94 VIN = K C,K,G
L35 CPI 4.3L 94 VIN = W S,T,M,L
LB4 TBI 4.3L 94 VIN = Z G,M,L,S,T,C,K
LN2 MFI 2.2L 94 VIN=4 S
* LN2 MFI 2.2L 94 VIN=4 S
Look at the ALDL def you have and see which one matches it and then see if you can find another mode 1 dump command in that defintion for the trans. It will probably have line pressure.
Old Sep 16, 2009 | 02:43 PM
thanks, i will check it out
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
