ECM question
Old Sep 23, 2009 | 09:41 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
ECM question
I have an ECM from an 87 305 TPI firebird, from what i gather, the posibilty of VATS in it is hit or miss? if i have VATS in it, all id need is a prom from an 87 305 TPI camaro right?
Old Sep 24, 2009 | 02:47 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: ECM question
The VATS is not in the ECM itself, but its a setting in the PROM that plugs into the ECM, as well as a separate black box that reads the resistor in the key when you put it into the ignition. GM didnt start using it in f-bodies until late in 1988, and then in all f-bodies in 1989 and newer.
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 10, 2015 08:42 AM
