305tpi, supercharged max timing?
Old Oct 20, 2009 | 08:08 PM
customirocz's Avatar
Car: 86 Iroc-z
Engine: worked 350tpi
Transmission: built 700r4
Axle/Gears: auburn pos 4-10
Im running a 305 tpi with a mild cam, stock heads but polished and ported,headers and exhaust,52mm throotle body, 24lb accel injectors,53lb fuel pressure, paxton charger at 6lbs my base timing is set at 6 degrees what should my full advance be around? Im useing tunerpro rt and Blowerworks had set it to 41.8 max advance.i pulled my spark plugs tonight after running his program and the plugs are barely tan with black specs that seems to me like detonation too lean and or maybe too much advance? any thoughts?
Old Oct 20, 2009 | 10:46 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: 305tpi, supercharged max timing?
MAX timing is fine as long as its less than 45... 41.8 is stock setting and should be fine. it depends on the timing in the timing tables. you have to retard the timing for every lb of boost i thought? are u increasing fuel pressure for every LB of boost with an FMU?
specs could be too rich... im not a good at checking spark plugs. wat is tunerproRT telling you? knock? retard knock timing? anything? wats ur timing tables look like? how are u retarding timing for boost an increasing fuel for boost?
Old Oct 21, 2009 | 08:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Suggested reading:
https://www.thirdgen.org/techbb2/sho...hreadid=317768
RBob.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
toronto formula
Nov 10, 2015 06:17 AM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
jbd1969
Aug 17, 2015 07:06 PM
