Duts87ss
close
- Join DateAug 2005
- LocationOcean Springs, MS
- iTrader Positive Feedback100
- iTrader Feedback Score(10)
- Car1987 Monte Carlo SS
- EngineHSR 383 AFR180/268XFI EBL
- Transmission200-4R, Edge 2800 L/U
- Axle/Gears7.5/3.73/PowerTrax No-Slip
- Liked:0 Times in 0 Posts
Is there anyway to log MAF voltage with TunerPRO? I'd like to be able to create a histogram to average my BLMs at a given voltage. I could use grams/sec, but would have to change the histogram every time a MAF table changes.
Duts87ss
close
- Join DateAug 2005
I've created a spread sheet that should allow me to place the avg BLM for a give MAF value and then covert it to its new value. Basically (BLM1/128)*Gram/S1=Gram/S1a...(BLM2/128)*Gram/S2=Gram/S2a... and so on.
I've got the MAF voltages (from the MAF tables) labeled across the top row and frozen (always at the top) to keep me oriented to where I am.
Anyone see any issues with this method? If it works, I'll make it available for everyone.
Duts87ss
close
- Join DateAug 2005
I got a 15-20 minute datalog yesterday afternoon to try out my new MAF Table calculator. It seems to work pretty well so far; of course, I haven't gotten but the one session yet. I did get some inconsistancies in Table 6, but hope these will start to correct themselves the more I tune the car.
Duts87ss
close
- Join DateAug 2005
Got a second data log today and things seemed to be a bit more in line; so, here it is. You'll need to replace the first row of Gram/S values with your own. I should have put the info in rows instead of columns, but it's easy enough to paste it into a new file and then convert from rows to columns. Once you have it in columns, you just copy and paste into the corresponding MAF tables.
