7730 memcal question
Old Feb 25, 2010 | 08:26 PM
JoeK18's Avatar
Car: 1991 Camaro RS 1953 Chevy Bel-Air
Engine: 305 tbi and 283 Eddlebrock
Transmission: 5 speed std. 700R4
Axle/Gears: forgot?
Hi guys, I got a 7730 out of a 6 cyl. Camaro at the salvage yard. I want to use it for a 350 TPI in my street rod. The memcal in that ecm is from a six cyl, I want to cut the chip out, desolder the pins and insert a new programmed sst chip. But how about that blueish gel part of that memcal. Is that part of the the knock sensor circuit? Is that memcal only good for a 6 cyl. ? I hope I dont need to buy another memcal. Any info appreciated. thanks.
Old Feb 25, 2010 | 09:05 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 7730 memcal question
You don't need to desolder the existing chip, just use a MEMCAL adaptor, such as the G1 from Moates.net.
The biggest issue is the other end of the MEMCAL, that is the CALPAK. There is a cyl select setting that is determined by the resistor network. Now there are ways to modify the CALPAK for proper cylinder selection. There is a thread dedicated to this in the forum. Do a search on MEMCAL modifications and it should come up.
Old Mar 1, 2010 | 08:58 PM
JoeK18's Avatar
Axle/Gears: forgot?
Thanks sixshooter, I will check it out.
Old Mar 4, 2010 | 03:31 PM
JoeK18's Avatar
Axle/Gears: forgot?
Hi sixshooter, sorry, I searched all them posts and didnt find nothing about changing the calpak resistor network from a 6 cyl to a 8 cyl., unless I missed it somehow. I wish I can find out how to do it. If I cant I'll have to buy a new memcal. What about those 2 chips under the calpak? How are they involved? Any further help will be greatly appreciated! Please help! Thanks, JoeK18
Old Mar 4, 2010 | 08:54 PM
The large white board is not the CALPAK, that is the knock filter, the "chips" under that knock filter is the CALPAK, and theres a couple pins that get shorted.
Try searching using "Memcal" or "CALPAK" and other related terms, and the thread(s) will come up.
Old Mar 4, 2010 | 10:36 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
https://www.thirdgen.org/forums/diy-...es-values.html
Please post your results.
Thanks,
mddaniel
Sep 8, 2015 05:16 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Keith5
Aug 27, 2015 04:37 PM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
