EBL intro tune part 2
Old Mar 31, 2010 | 01:51 PM
Ronny's Avatar
Injector Compensations:
The purpose of injector compensation is to make up for the time it takes for an injector to open and then close. The proper values can be difficult to obtain, so many times they are guessed at based on results. Which in many cases works out OK.
In general terms the higher the fuel pressure the longer it takes for an injector to open. Increased fuel pressures are more prevalent on TBI systems. And as such should have the injector compensation values increased. Check the 5.4l calibration with the 80# injectors at 22 psi. Compare those values with some stock calibrations. That will give an idea of what values can be used.
I see two that may be applicable.
Injector correction multiplier. Voltage based. I understand a lower voltage will make inj opening slower. So I upped those 10% for 80 lbs inj @ 19.5 FP. 14.4 I assume is neutral being at zero so I changed to 2.34.
Injector correction offset. Again V based. I added 10%.
Please define correction offset.
Old Apr 1, 2010 | 07:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL intro tune part 2
Correction offset is an adder to the PW. Just adds a set amount as defined by the table.
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
