4X Vpw Hardware help
Old Jul 13, 2010 | 11:26 AM
planethax's Avatar
So I have a guy working on some hardware for me.
He has run into an issue activation the 4X Vpw, wondering if any had some knowledge to help out.
From His latest Email
PLanet
Here is where I am.
Send request to disable normal messaging ---- positive response
Send Request High Speed Mode ------------------- positive response
Send Begin High Speed Mode ------------------------ No response at all
Have not been able to make any more progress. If I send a 4X message to read codes there is no response.
Question - is this the normal sequence to initiate 4X mode?
PLanet
Do you know if the’ Begin High Speed Mode’ has to be sent after the ‘Request High Speed Mode’? I get a positive response to the Request High Speed Mode command but it’s not responding to commands I send at 4X after that.
Some more info I have from him
(I have sent him this document) http://planethax.com/PCMcomms.xls
Yes. After sending the Begin High Speed Mode, I wait for a response but it never comes. I have tried sending the Begin High Speed Mode in both 1X and 4X speeds but never see a response message, and I have a scope on the bus in case the software misses the response.
Here are the transmitted messages:
6CFEF12800000 'send request disable normal messaging
6Cfef1A000 'send request for 4X data
6CfeF1A100 'send request start 4X data, sent at 4x rate
Never see response from the last message
Is there a way to set the PT in monitor mode and use a Hyperterm type app to monitor data?
I am able to do this with the Elm, but obviously overflows once my Tech2 goings into 4X
Old Jul 21, 2010 | 02:43 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: 4X Vpw Hardware help
I missed this thread earlier...
Is the engine off? Have you requested (and obtained) security access to the PCM? 4x only happens when you have the engine off, are in secure data access mode.
What are you trying to use it for? It can only be used for reflashing or reading the flash chip. Datalogging and other functions are not normally available in 4x mode due to the large number of interrupts generated by the VPW controller.
Old Jul 21, 2010 | 02:50 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Obviously the ELM will not work, but what is he using to connect to the PCM? Is the PCM alone on the network (like, on the bench), or is it in the car? IIRC, the 4x sets in as soon as you make a valid request for it. So, if the hardware has trouble in 4x mode, you will not get a reponse saying that your in 4x mode
88SS6SPEED
Nov 11, 2015 07:05 AM
sjorgens
Oct 1, 2015 07:54 PM
dbrochard
Sep 25, 2015 04:56 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
