WUD Display changes?
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
In my WUD screen the title "INT" sometimes changes by itself to a different title. I've seen a variety of different terminology in there. Do they mean something?
Example of it below... where INT should display it displays instead a 3.3
Car: check
Engine: check
Transmission: check
Re: WUD Display changes?
How did you do that? Kidding aside, which version of the WUD is this? Can get it from the help about menu entry.
One thing I've noticed about Windows is that it can't always keep up with the update rate of the main WUD display. This is apparent when resizing, minimizing or maximizing a window.
When that happens the display gets goofy. Although it is usually in the gauges. Having Windows completely re-paint the display fixes it. Can force a re-paint by opening another window on top of the WUD then bringing the WUD to the foreground.
The "INT" annunciation should always be displayed. From the version I'll go look to see if some debug code was left in. Although I would imagine that others would have mentioned this too.
There is a newer version of the WUD. Shoot an email to our update @ email address and it will get sent right out. No guarantee that it will fix it, as I don't yet know what is causing the display error.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
OK, new version sent, let me know if that helps. The other item I noticed on your display is the WB device name. It too doesn't look correct.
Off hand, were they other numbers, or were there letters/words there too.
RBob.
RBob.
Car: Corvette
I got it, thank you.
Nothing different that I've noticed in the WB... right now I don't have that connected up either.
Street Lethal
Apr 30, 2019 12:14 PM
two-if-by-sea
Aug 31, 2015 06:30 PM
