spark tuning.
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
spark tuning.
I know this is a very vague question, but...
what vehicle parameters affect spark advance the most and why?
Re: spark tuning.
In general the greater the load on the engine (less vacuum/more throttle applied) the less advance must be. The higher the rpm, the greater the advance must be.
These two rules must be applied simultaneously.
One example is, at 2000 rpm and 30kpa manifold pressure (no throttle) timing would be around 25 degrees (or more depending on application). But at 2000 rpm and 90kpa manifold pressure (almost full throttle) timing must be decreased to around <15 degrees.
You should buy a book called designing and tuning high performance fuel injection systems by Greg Banish. There is all you need to know about tuning in there.
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
