0D injector constant calculation
Old Dec 31, 2010 | 09:15 PM
jim_in_dorris's Avatar
Ok, I am back at $0D again, this time converting a $0D bin to MPFI (tuned port)
for a friend's kids 383. He is using ACCELL 30#/hr injectors, and I need to calculate the injector constant. However, when I looked at the formula I couldn't even work it out to get the stock answer.
; INJECTOR & ENGINE SIZING CONSTANTS
L4D88 FDB $15C6 ; 6.8 GMS/SEC INJ FLOW RATE 13.6/BANK
; CAL N * # Injectors / 409.6
$15C6 is decimal 5574
5574= n*2/409.6
5574*409.6=n*2
5574*409.6 / 2 = n or n = 1141555.2 ???? what??? I know I am doing something grossly wrong here, but what?
Old Jan 1, 2011 | 01:12 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Engine: 355 cu. in. Vortec / TPI / MAF
Axle/Gears: 3.73 Limited Slip
Re: 0D injector constant calculation
I'am using XDF file v1.75 look under engine constants and you well see injector flow rate ( MPFI lb/hr ) type in the size of one injector ( 30 #/hr ), then scroll down to injector flow rate ( MPFI gms/sec ) an divide one injector by number of cylinders ( 8 ) = 3.75 gms/sec . In reference to the code 4D88 an 4D89 , just a reminder don't forget to change the cylinder volume ( 4D8A )
Old Jan 1, 2011 | 02:59 PM
Thanks 95. Actually, I am trying to arrive at $15C6 using the 6.8 gm/sec figure in the comments. If I can get that calculation correct, then I can size it for any injector I use. It is good to know that 3.75 gm/sec is what the 30# flow at.
Old Jan 1, 2011 | 05:20 PM
Okay, I actually figured it out. the formula is incorrect in the SRC file I was using. Thanks to the tip from 95 4x4 I dug into tuner pro and found the formula to be
x= gm/sec * 819.2
or x = gm/sec * # injectors * 409.6 !! not divide by 409.6
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
