bin differences
Old Apr 27, 2011 | 05:08 PM
evo6z28's Avatar
Car: 1992 Camaro Z28
Axle/Gears: 2.73 Limited Posi
bin differences
My current ECM uses the AUJW .bin and from what I understand the AZTY .bin is the latest update. What are th differences in the two .bin files? Could I use the AZTY bin when emulating and datalogging and everything else? My car is a 1991 V6 camaro if that helps any.
Old Apr 27, 2011 | 05:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: bin differences
I don't know what the differences are. Can you post the AUJW bin?
To the second question, I would move to AZTY as it fixed a few issues in the calibration.
RBob.
Old Apr 27, 2011 | 06:17 PM
evo6z28's Avatar
Re: bin differences
I would love to if someone could tell me how to import the .bin from my stock chip. Does the AZTY .xdf read the AUJW .bin? Im still learning this stuff guys so bear with me.
Old Apr 28, 2011 | 09:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: bin differences
You would use the $88 XDF for both bin files. But that is to edit them. To read the AUJW chip need a PROM burner/reader.
RBob.
Old Apr 28, 2011 | 10:26 AM
evo6z28's Avatar
Re: bin differences
I have an AutoProm, How do I make it read the stock prom?
Old Apr 28, 2011 | 02:39 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: bin differences
Should be able to. Hit www.moates.net for the documentation on using the autoprom. Will need a header or to remove the chip from the MEMCAL. The header is the easiest method.
RBob.
69GTOby
Apr 18, 2016 02:34 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
greenyone
Sep 2, 2015 03:39 PM
