need some advice on some mild cahnges
Old May 3, 2011 | 11:22 AM
tmmilas's Avatar
I did a few things to my truck and am trying to get the hang of tuning. I would like to know is a good starting point on my AFR and timing. I am using a holley 502-9 65lb injectors, raised manifold, and a very mild cam (edlebrock 2102). I am having trouble finding info for AFR values and timing changes........ I am using a 16147060 BAAY setup on a 93 chevy k2500 5.7l tbi. any info is welcomed thanks>>>>>
Old May 3, 2011 | 04:38 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: need some advice on some mild cahnges
Target stoich in closed loop to keep the 3-way cat happy. In PE mode, well, 12.8:1 is ideal for most N/A engines. But may need to enrich that to prevent the cat or engine from melting from prolonged WOT.
Timing, shoot for MBT without detonation. Then adjust for drive-ability.
RBob.
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
FueledSoul
Sep 30, 2015 09:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
