EBL help
Old Jul 2, 2011 | 03:33 AM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
EBL help
Im trying to tune my car and learn after learn it seems to be better but 2 things I cant figure out.
When I accelerate the fuel spikes lean and slowly adjusts (with the learns its getting better) but when cruising and Im off the gas it goes extremely rich to the point now that Im stalling the odd time.
When Im on the gas it runs stoich, off the pedal very rich while moving at any speed but at a dead stop it adjusts to stoich.
I have been trying to get my car running with the EBL for some time now with BobR's help, being a complete newb to this I find is taking a long time to get right.
Any help is appreciated.
Thank you
Old Jul 2, 2011 | 06:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL help
Thank you
Most likely open loop decel is set:
Option Word 3 - Bit 5 - OpDcl
Un-check that option flag for some VE Learns. Then when the decel fueling is close enough set the flag again.
Once the fueling is closer it is likely to start surging on decel (from proportional gains). Which going open loop on decel prevents. If it continues to lightly surge on decel once the open loop decel flag is set, add some VE back into the low MAP column(s) of the VE table.
RBob.
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
