adjusting idle afr?
Old Jul 12, 2011 | 09:23 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
adjusting idle afr?
I was just curious how the open loop and closed loop afr is adjusted. At idle my blms are 133 and WB shows 14.7 to 15.2... Also will adjusting idle afr affect cruise and wot? Thanks
Old Jul 13, 2011 | 03:28 PM
Car: 89 Formula 350
Re: adjusting idle afr?
anyone? Also I should add I'm using Tuner Pro 5
Old Jul 13, 2011 | 05:53 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Can't say this would be the best way, but since AFR is indicative of rich/lean. I'd add/cut fuel around my rpm and Kpa idle points It won't be just one point, it will be a target with your ideal idle point in the middle of the bullseye.
Maybe others have figured out a better way.
Old Jul 14, 2011 | 01:58 PM
ULTM8Z's Avatar
What do you want to adjust it to? It looks pretty good to me the way it is.
Old Jul 14, 2011 | 02:13 PM
Car: 89 Formula 350
yeah it was close but i got it alittle better. Between 14.6-14.9 now, I went into MAF table 1 , think it was row (4)55v and went from 7.01 to 8.00..Thanks for the help guys
86CamaroDan
Sep 29, 2015 10:08 PM
86IROC112
Aug 21, 2015 07:20 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
