EBL VS EBL P4
Car: 91 Z28 camaro
Transmission: T 5
Axle/Gears: yukon duragrip 4.11
EBL VS EBL P4
hey has what is the diffrence between these to systems and the benifits of the ebl p4? Also what are the benifits of the port mod?
Transmission: 5-speed/T-5
Re: EBL VS EBL P4
The difference is the base ECM that they are used in.
The EBL is to be used in some C3 style ECMs, such as the 1227747, and similar.
The EBL P4 is meant for the P4 style ECMs, such as the 1227730, 1227727, and similar.
The port mod to the EBL is to provide the correct firing scheme when using the EBL with an MPFI set-up.
Car: check
Engine: check
Transmission: check
Re: EBL VS EBL P4
