Ostrich 2.0 questions
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Ok I just got my Ostrich 2.0 and have the latest TunerPro RT. I am using an ALDL cable from aldlcable.com for datalogging. For some reason ever since i downloaded the latest Tunerpro RT I haven't been able to datalog. Tunerpro won't connect but it will find the ostrich. My question is do I need to use the aldl cable with the ostrich to make changes on the fly? I wish this ostrich came with a user manual but it didn't so I'm not sure if I'm doing this right.
Transmission: 5-speed/T-5
Re: Ostrich 2.0 questions
Have you set up the data acquisition side of Tuner Pro RT?
No you don't need the ALDL cable to tune the Ostrich, but it makes things much easier to know what the ECM is doing to know that you are changing things in the right direction.
Well I used to be able to plug in the aldl cable and hit the arrows in the tool bar and connect but it won't connect for some reason. The ostrich and aldl can be connected at the same time in Tunerpro rt right?
The way your first post reads is that, you downloaded a newer version of Tuner Pro RT, and without setting anything up, wanted to connect to the ALDL. So I ask again, did you set-up the data acquisition? (com port, ADX file, etc.)
Yes, the Ostrich and ALDL cable can be connected at the same time.
In Tuner Pro RT:
Tools>Preferences>Data Acquisition >Configure Plug-in Component.
*UPDATE*
Got everything working correctly. Found a thread on the Tunerpro forum that addresses the glitchy display on Tunerpro RT v5. Data tracing works perfect. Thanks for your help
