WTH, open loop blms moving around at idle
Old Nov 3, 2011 | 03:40 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
hello again,
SAUJP tuning
so yesterday i was playing with the tune a little and threw it into closed loop to see how far off my O2 tables are, which is alot. put it back into open loop and the blm was at 138 but after closed loop it moved to 128. now i have to retune the VE cells because it was at 138 before. idles in cell 4 too. so how the heck is the blm able to move in open loop, and how can i lock the damn thing from moving?
trying to track down a low rpm cruise shake/surge that violently rocks the car at very light throttle or when exiting DFCO, and also trying to try down a frequent stall problem when warm, stall saver tables are zero'd. its a T5 car so when im backing out of a parking spot is when it happens the most. would i benefit by switching to a factory AXXD bin but keep the SAUJP mask and adx?
Old Nov 4, 2011 | 02:08 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: WTH, open loop blms moving around at idle
I think it is just "resetting" the BLM, the obvious clue is 128.
Old Nov 4, 2011 | 03:57 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
true,BUT, if it moves to say 138 while in closed loop it will stay there when placed in open loop and remain at that value until the next time closed loop is enabled. also, any other time throughout the load range it will go to 128 but return to 138 at idle. hope that explains it a little more
Old Nov 4, 2011 | 07:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In $8D two of the sixteen BLM cells are saved and restored at key-on. There is an upper & lower limit to the restored values, set those to 128.
RBob.
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
AkDrifted
Aug 17, 2015 07:45 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
