Fuel pressure sender question EBL
Old Dec 2, 2011 | 10:07 AM
kataklysm01's Avatar
So, I'm thinking of putting one of these on the dash.
http://www.glowshiftdirect.com/blue-...ure-gauge.aspx
The senders are rated from say 10 -180 ohms, what does that translate to in voltage? I'm a little rusty on Ohms law. If the voltage going in is 12V, what should the outgoing V be when affected by a resistance?
I should be able to hook this up to the EBL and create a fuel pressure device if I know the voltage span. yes/no?
Unless someone has a better idea?
Old Dec 2, 2011 | 04:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fuel pressure sender question EBL
Whatever you do, do not connect 12 V to the EBL ADC inputs. The maximum voltage is five (5 V).
As for using that sender, I'm not sure if it will work with the EBL. Some gauges have a data logging output that is linear. If it is within the 0 - 5 volt range that will work with the EBL.
Many users (including myself) use the AutoMeter pressure transducers. They take a 5 V source and output a linear 0.5 - 4.5 V range. The devices are also built into the WUD so no need to create a user device.
The 5V power source can be obtained from the MAP/TPS reference voltage.
RBob.
Old Dec 2, 2011 | 05:22 PM
A 'transducer', sounds like something out of a 1930s sci-fi comic. Is that going to teleport me in and out of my jeep?
Alright, so Summit carries a Holley version of the atomic blackhole accelerating transducer. Specs match the 5V source, linear 0.5-4.5V, 0-100psi.
http://www.summitracing.com/parts/HLY-554-102/
Thanks mucho for the instructions.
I've got so many Summit stickers laying around, my 4 year old told me she was sick of them tonight. She gave 'em back to me. Sheesh.
I suppose you could wire one of those for oil pressure and set the EBL to shut off the engine if the oil pressure dropped below a threshold. If the EBL had such an option.
Old Dec 2, 2011 | 07:09 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Also Autometer 2246 (0 to 100 PSI). For TBI system use Autometer 2239 (0 to 30 PSI).
//RF
Old Dec 3, 2011 | 10:45 AM
Can EBL make use of the fuel pressure signal besides the usage in WUD for logging purposes? Does the ECM use the values to calculate anything?
Old Dec 3, 2011 | 12:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is for data logging only. Which is important as it confirms that there is a sufficient volume of fuel. Most fuel delivery issues show up during heavy AE and sustained WOT.
RBob.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
