VSS readings in TP
Old Mar 22, 2012 | 03:37 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
VSS readings in TP
I'm getting an intermittent issue with my VSS circuit. Its is jumping all over but only when the car is in park not in gear. It shows to be going 0-70mph in park in my datalogs as well as the speedo jumping in the cluster. I know the VSS isnt moving in park. I've replaced the VSS, VSS buffer, Cluster....Any ideas?
Old Mar 22, 2012 | 11:55 PM
EagleMark's Avatar
Re: VSS readings in TP
Is it only VSS jumpy? No other sensor readings?
Could be a loose conection in wiring somewhere, between salt and potholes back there anything could be possable? You've already replaced the obvious.
HTH!
Old Mar 23, 2012 | 11:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
EMI
Old Mar 23, 2012 | 11:50 PM
EagleMark's Avatar
Ah yes, the twisted pair from VSS getting interference from something. Do they run anywhere near coil or spark plug wires?
Old Mar 24, 2012 | 09:34 AM
Car: 89 Formula 350
I did only start getting this problem after installing my MSD... Sometimes I don't have any issue for a few weeks...I've mostly noticed it in park, also I had a few spikes in the speedo reading at slow very slow cruise
Bubbajones_ya
Jul 6, 2024 08:32 PM
GTAman
Jul 3, 2024 07:29 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
sandman92084
Sep 12, 2015 10:27 PM
