help please
Car: 1988 GTA Trans AM
Transmission: 5 speed
help please
So i removed my ECM from my car and found out that the previous owner replaced the ECM and chip, there is a Hypertech chip installed.
My question is how do i know what the chip was programmed for? I am tryn to fix my vacuum lines, ran into a issue with the EGR not connected, then found I dont have a EGR solenoid or even a plug to plug a egr solenoid into
I was going to get a after market adapter that u plug the factory chip into, the adapter has a chip that u can have set for EGR disabled
So how do i find out what the chip installed is configured for? I really need to get this figured out as my car now has a real rough idle, no power on acceleration
can i pull the chip and flash myself? any and all help is appreciated
Re: help please
my check engine light doesnt turn on, I assume the previous owner removed it
i am going to remove dash tonight and install a bulb, then i will short out computer and read the flashes
to save me some searching, does anyone know off the top of there head what pins to short to get it to flash out the codes?
Re: help please
While your here:
http://www.gearhead-efi.com/Fuel-Inj...-CEL-SES-Light
Get the PDF at bottom of page and save so you can diagnose each code and circut.
Re: help please
