Throttle at 11% even though .54v
Old Apr 30, 2012 | 08:37 AM
Scorp1us's Avatar
I've for a weird problem and I've been though a few ECUs.
16197427 5.7L on a IH 345 tuned timing and fuel to be "ok"
It always wants to idle high. So I set the idle vs temp points to all be 650. It still likes to idle at 1100-1400. Sometimes it will idle correctly. But if I start it, stop it, and start it again I am guaranteed it will idle high.
That's when I noticed it said 11% throttle on the TunrerPro dash. But the voltage was correct (+/-0.2 @.54v)
I've also had idle oscillations.
I've had nothing but trouble with my IAC. I can't get it to close on the IAC reset procedure. But it does work. I've been through multiple IACs and multiple 16197427 PCMs
I'm thinking maybe that the IAC is staying too open and isn't resetting between the engine off/on time. How much time does it need?
Old Apr 30, 2012 | 11:24 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Throttle at 11% even though .54v
if your throttle is anything other than 0% or maybe .39% at idle, you'll have idle speed issues.
i've had an issue where if my ECM went into limp-home mode due to a bad tune(or bad contact), when i would replace the chip, TPS% was always at ~2.x% when i was at idle, with correct TPS voltage.
pull the battery power to the ECM for a few seconds, key-on, then the % is fixed.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
HoosierinWA
Oct 7, 2015 10:15 AM
