Timing for AFR Eliminator 180 Heads ?
Old Sep 12, 2012 | 04:15 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi All,
I put AFR Eliminator 180 heads on my Son's 1988 L98 IROC-Z.
Presently running the stock Advance vs. RPM vs. Load table.
Does anyone have a recommended Advance table?
I heard (rumor mil) that these heads do not require very much advance. At least for carb applications.
Best Regards,
Bruce
Old Sep 12, 2012 | 04:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Timing for AFR Eliminator 180 Heads ?
They typically seem to like 30-34 deg at wot depending on compression and gas. Most cruise areas at lower loads seem to tolerate 34-36 deg or so for me. More would be nice if it takes it but my last motor didnt seem to want more than 35-36 at cruise
Old Sep 12, 2012 | 04:40 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
34 seemed to be my sweet spot on my 195's.
Old Sep 12, 2012 | 04:54 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Thanks Guys.
I looked at the stock L98 table in the bin.
17.93 17.93 17.93 17.93 17.93 18.98 20.39 21.80 20.74 20.04 20.04 20.04
16.17 16.17 16.17 16.17 16.88 18.28 20.04 20.74 20.74 20.04 20.04 20.04
15.47 15.47 15.47 15.47 15.47 17.93 20.04 21.09 22.15 20.74 20.74 20.74
17.93 21.09 24.61 24.61 26.02 25.66 22.85 22.85 22.85 18.98 18.98 18.98
18.98 23.91 28.13 27.77 27.07 22.15 18.98 17.93 17.93 16.17 16.17 16.17
19.69 26.02 30.94 30.94 30.94 28.48 23.91 22.15 22.15 18.98 18.98 18.98
21.09 35.86 35.51 34.45 33.75 33.05 29.88 26.02 23.20 22.15 22.15 22.15
22.50 33.40 35.86 35.86 35.16 34.45 32.70 26.02 23.20 22.15 22.15 22.15
22.50 33.40 35.86 35.86 35.86 34.81 33.40 29.88 26.02 24.26 22.15 22.15
22.50 33.40 35.86 35.86 35.86 35.86 34.45 32.70 28.83 24.26 22.15 22.15
22.50 33.40 35.86 35.86 35.86 35.86 35.16 28.83 26.02 24.26 22.15 22.15
22.50 33.40 35.86 35.86 35.86 35.86 35.16 27.77 24.26 20.04 20.04 20.04
22.50 33.40 35.86 35.86 35.86 35.86 33.05 27.77 23.20 21.09 20.39 20.39
25.31 33.75 37.97 37.97 37.97 35.86 31.99 26.72 24.26 21.80 20.04 20.04
25.31 26.72 29.88 33.75 33.75 35.86 32.70 27.77 25.31 21.80 20.39 20.39
25.31 33.75 37.97 37.97 37.97 35.86 31.99 27.77 24.26 23.91 22.50 22.50
33.75 40.08 40.08 40.08 40.08 37.97 35.16 31.99 28.83 24.96 23.20 23.20
Sorry about the poor looking map.
I have not run the engine very hard. Looks like I should limit the values about ~36 degrees?
Best Regards,
Bruce
Old Sep 12, 2012 | 08:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If you are starting a fresh tune keep it low for now and then as you get air fuel ratios in line, add more timing and see what it does
evilstuie
Jan 9, 2020 08:29 PM
CRFred
Feb 7, 2016 11:39 PM
lakeffect2
Aug 23, 2015 08:44 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
