EBL-Analysis-AE
Old Sep 27, 2012 | 03:44 PM
Ronny's Avatar
EBL-Analysis-AE
AE event apparently reduced INT and eventually reduced the BLM from 131 to 126.
I thought VE-Learn will not be affected by AE. Maybe the Learn was not affected but BLM was and that event was ignored in Learn?
Does this mean I have too much AE fuel? I believe my WB dropped into 10's as it is not patched into log(yet).
Old Sep 28, 2012 | 10:50 AM
Ronny's Avatar
Re: EBL-Analysis-AE
I did another Learn this am and again on a mild accelleration 55-62 mph INT drops from 130 to 113 BLM drops from 126 to 122.
Old Sep 28, 2012 | 11:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL-Analysis-AE
A VE Learn won't reduce the AE. Need to do that manually.
RBob.
Old Sep 28, 2012 | 11:26 AM
Ronny's Avatar
Re: EBL-Analysis-AE
I am not trying to reduce AE.
What I am asking is why does the AE event affect my BLM?
I thought when in AE, the BLM is not affected or is it that the resulting drop in BLM is ignored in a VE Learn thus not appearing in correction %'s?
Old Sep 28, 2012 | 12:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL-Analysis-AE
There is a flag to lock the INT at 128 when AE is active. That will prevent the BLM from moving.
However, when there is too much AE the INT will move once the event is over. As it is still rich from excess AE.
RBob.
Old Sep 28, 2012 | 01:11 PM
Ronny's Avatar
Re: EBL-Analysis-AE
Flag was not set. Now it is. thank you.
