Rbob? Someone?
Old Jan 25, 2013 | 10:20 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Rbob? Someone?
Attached is a snippet of code and bin/definition files for something I've been working on for awhile that I can't get to run right. The older version of this would occasionally kick out of power enrich at WOT and this is my latest attempt at a fix but it's not better. It dies on startup after it loads up with fuel, if I play with the throttle it will struggle to run for a bit while the check engine light quickly flashes and eventually it will die again. This is for a modified version of $6E that's using a map sensor instead of the LV8 calc.
What it's supposed to do- it will enter power enrichment if either the tps or kpa exceeds table values and it will only end power enrich after both the tps and kpa are low enough.
There must be something obvious I'm missing. Thanks for any help in advance.
File Type: txt
File Type: zip
Old Jan 26, 2013 | 10:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Rbob? Someone?
Biggest item is checking for underflow after the subtracts:
Code:
D919:		 SUBA    LC4FF			; %TPS HYST FOR PWR ENR
                 BCC     LD922			; bra if no underflow
                 CLRA				; clr underflow
D922:  LD922     CMPA    L0083			; TPS Val
This needs to be done after nearly every subtract or add instruction. This may be why is would drop out of PE mode from time to time.
I rewrote the code segment with that change along with simplifying it some:
Code:
	; PWR ENR MAP THRESHOLD vs RPM
D8F2:  LD8F2	 LDX     #$C501			; PWR ENR MAP THRESHOLD vs RPM
D8F5:            LDAA    L0058			; RPM/25
D8F7:		 LSRA
D8F8:		 LSRA				; RPM/4
D8F9:		 PSHA
D8FA:            JSR     LF3FF			; Call 2d Lk Up, (No Offset)
D8FD:		 BRCLR	 L0044,#$20,LD904	; Branch if Not Pwr Enrichment
						; ... else
D901:		 SUBA    LC4FE			; LD VAL HYST FOR PWR ENR
                 BCC     LD904			; bra if no underflow
D904:  LD904     CMPA    L0064			; Load Val
D90C:            BLO     PeOn			; bra if theshold < MAP
	;  PWR ENR TPS THRESHOLD vs RPM
    	;  TBL =  2.56  * %TPS
D90E:  LD90E	 LDX     #$C506			; PWR ENR TPS THRESHOLD vs RPM
D911:	         PULA				; RPM/4
D912:            JSR     LF3FF			; Call 2d Lk Up, (No offset)
D915:		 BRCLR	 L0044,#$20,LD922	; Branch if Not Pwr Enrichment
						; ... else
D924:		 BHS 	 PeOff			; bra if thres >= TPS%
D926:  PeOn	 BSET    L0044,#$20		; set bit
                 BRA     PeDone			;
       PeOff     BCLR    L0044,#$20		; clear bit
       PeDone:   $				; done
D92C:            BCLR    L003A,#$80 ;; ???
RBob.
Old Jan 26, 2013 | 11:45 AM
bl85c's Avatar
Car: '85 maro
Re: Rbob? Someone?
Excellent, thanks I'll try it out.
Old Jan 26, 2013 | 12:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Rbob? Someone?
Note that it no longer branches to LD95D, so be sure to take that into account when grafting in the new code.
RBob.
Old Jan 31, 2013 | 01:14 PM
bl85c's Avatar
Car: '85 maro
Re: Rbob? Someone?
BTW this works properly now, thanks.
Old Jan 31, 2013 | 03:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Rbob? Someone?
Cool beans, thanks for getting back to me. And you're welcome.
RBob.
Rocket-Doc
Nov 14, 2015 02:08 PM
CORV3TT3
Aug 23, 2015 11:26 AM
jwscab
Sep 16, 2004 07:40 PM
jwscab
Sep 10, 2004 08:49 AM
