Trying to load a 32k bin on 27SF512 chip...
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
for $8D definition file, i am using starting address of 8000hex. Should the buffer address be the same? Using a Moates BURN1. I normally burn the 29C256 chips with a 16k bin, and start at 4000hex. So i know the BURN1 is good.
when i read the chip back, it does not verify, and shows FF for the first half and 00 for the second half.
Need help!
Need help!
Transmission: 5-speed/T-5
Re: Trying to load a 32k bin on 27SF512 chip...
Car: 1988 IROC-Z
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Dont have a spare 512 chip to try do you? Perhaps reinstalling the moates driver and reinstalling your tuning program?
Just throwing some things out there.
Car: 1988 IROC-Z
sorry to hear that,
just burned a couple of 27SF512 chips today without problem
Not sure if the Burn1 is the same as the Burn2 but it was giving me weird problems like you are describing because I had the chip in the wrong end of the burner. Facing the right way but in the wrong slots in the burner.
A noob mistake but these are my first ones.
efiguy
Sep 27, 2015 01:30 PM
