New stall - adjust TCC lock value?
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
I put a higher stall (2050) into my 89 5.7 GTA. OEM converter was <1500 RPM.
- First question: Is it better to use RPM or MPH as the basis for TCC lockup? The 6E xdf has MPH.
- Second: Should the lockup settings occur earlier or later with the new converter
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: New stall - adjust TCC lock value?
I put in a 2500 stall and feel that the car doesn't shift that properly from 1-2.. I set the lockup at 45MPH but that's way too early IMO.. I need to set it back up to something like 50 to 55 MPH.. I know this doesn't answer your question tho.. :/
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
hellz wingz
How is ur your ride coming. I have questions about your setup?
I would imagine the TCC is based on RPM,TPS and Mileage since it will vary based on the load of the engine?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I personally don't like the tcc to lock at a lower speed and prefer to have tcc set around 50-55mph. If your after fuel economy bin stack and do two different tunes or you can always get the tcc to unlock off tps settings.
jcuff: Ok sure ask away.. PM me if unrelated to this thread.
Tuned: I will set mine back up to that because sometimes I am driving and have noticed that it kicks in too early (ex: speed up on an onramp to get on the highway...) and then I increase throttle and it unlocks.
Any way of tuning the 1-2 shift or is that purely mechanical in the tranny?
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
1-2 is set by the governor, you can get a recalibration kit and adjust the springs & weights but I found that I had to mess with the flyweights on the outside of the governor to get 1-2 where I wanted. But I have an extremely light/unusual combo so you might not need to.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
