need help with tuning
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
ok, heres my deal.
first off my car and mods
91 z28, 350 bored .030 (355)
gm zzz cam
edelbrock performer heads
HSR, stock tb, 24lbs ford injectors, afpr, set at 40 psi no vacuum, walbro 255
3.73 gears
700r4
b&m 2500 rpm stall converter
now my tuning stuff
moates chip burner
moates aldl cable
tunerpro rt
moates chip adapter
runnning a 7730 ecu with a $8d.xdf, downloaded a .bin labeled "anjf 90fcartpi700r4"
innovate wideband
i set all my flags and scalars. my question is what is next? where do i start? while driving i notice the afr is 10-11 at wot, so its running rich. any help would be great.
gm zzz cam
3.73 gears
700r4
now my tuning stuff
moates chip burner
moates aldl cable
tunerpro rt
moates chip adapter
innovate wideband
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: need help with tuning
Start with adding more sa or use a vette .bin, the work on your ve.
Wot is PE.
Wot is PE.
