Tunerpro find/add data signals?
Old Nov 11, 2013 | 10:21 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I am using Moates and Tunerpro. As I figure things out I have few basic that seem difficult to track down.
I have seen many people point to hex values as where a value or switch is. But it is unclear where that is Tuner pro.
For example: I am trying to find the default values for my MAF. Mine appear off but not sure. I am getting counts of 2300-3000 at idle. In Tunerpro it says it is pulling from the default values in definition property. Ok default what? Can I see the hex is it voltage, cfm, grains/sec?
Another example. I have the default signals in tunerpro. But how do I add/find new signals. For example I know there are signals for fans on/off or the intake air temp sensor. I like to add as a monitor. But even if I can find it in the pull down it ask for the hex address and signal values? How do you know what the value is in, the conversion etc?
Old Nov 28, 2013 | 09:52 AM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Re: Tunerpro find/add data signals?
Not sure exactly what you are referring to, but try highlighting an item in the TPro menu list of Scalars, Tables, etc. and press F2. The hex address will be shown in the popped-up window. Click on the Conversion Tab to see the formula used to convert the raw data.
Mark_ZZ3
May 24, 2018 01:02 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
ULTM8Z
Oct 2, 2015 01:25 PM
lewandom
Oct 1, 2015 08:15 AM
