6e and supercharging
Old Dec 28, 2013 | 10:41 PM
sparks454's Avatar
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
Anyone have a decent 6e file for a supercharged tpi motor. I am curious as to the timing tables and PE table value that you are running. I am using TunerPro, so if you can provide your tables or TunerPro .bin that would be great. I have a fueling issue that I am trying to work out since I added some boost. Thanks, Chris
Old Jan 3, 2014 | 07:24 PM
syntax terror's Avatar
Re: 6e and supercharging
Hi you might try $12p. It's code designed for the aussi 808 that is like the 165 you have except it uses a map sensor instead of maf. It can run up to 3 bar and has fuel and timing tables up to 9600. You will have to do some repining and remove the maf but that is not hard. Check it out http://pcmhacking.net/forums/viewtopic.php?f=27&t=356. Other wise put in a 7730 and run http://www.code59.org/index.php?PHPS...10;wwwRedirect
Hope that helps
Old Jan 4, 2014 | 07:28 AM
sparks454's Avatar
Car: 1987 GTA
Thanks syntax. I have gotten a few pm's and will likely go with a 7730 ecm sometime. First order is to pull the 30lb injectors and probably go up to 42's. I don't plan on running any more boost than 10psi in this car. It's not running lean on top, so for now there must just be another tuning issue that I am overlooking or haven't hit upon yet. Weather here is a foot of snow now so it'll have to wait for a while..Thanks again, Chris.
Old Jan 4, 2014 | 01:58 PM
You already have the 7165 so you would just have to repin a few wires so it would be less work.
