Choosing a Bin
Old Feb 7, 2014 | 11:47 AM
85 Frankenstein's Avatar
Car: 1985 Camaro Z28
Engine: 1988 305 TPI
Transmission: 1993 T-56
Axle/Gears: 3.08
Choosing a Bin
Hello, I was doing a little research and found this on an old thread:
From the TGO Tech Center FAQ:
Camaro:
89 5.0-F A/Trans(MD8) Fed, 2.77(GH3) 2.73(GU2) 16129297 9298ANYH
89 5.0-F A/Trans(MD8) Calif, 2.77(GH3) 2.73(GU2) 16129383 9384ANYZ
89 5.0-F M/Trans(M39) Fed, 3.08(GU4) 16129337 9338ANYR
89 5.0-F M/Trans(MK6) Fed, 3.45(GM3) 16129349 9350ANYS
89 5.0-F M/Trans(MK6) Calif, 3.45(GM3) 16129359 9360ANYT
89 5.0-F M/Trans(M39) Calif, 3.08(GU4) 16129365 9366ANYU
Firebird:
89 5.0-F A/Trans (MD8), Fed, 2.77(GH3) 2.73(GU2) 16133473 9334ANYC, 3506APYR
89 5.0-F A/Trans (MD8), Calif, 2.77(GH3) 2.73(GU2) 16133475 3513APYT
89 5.0-F M/Trans (M39), Fed, 3.08(Gu4) 16133478 3526APYX
89 5.0-F M/Trans (MK6), Fed, 3.45(GM3) 16133630 9375ANYX
89 5.0-F M/Trans (MK6), Calif, 3.45(GM3) 16133632 9379ANYY
89 5.0-F M/Trans (M39), Calif, 3.08(GU4) 16133988 9389ANZA
There is also Mike's site:
http://www.eecis.udel.edu/~davis/z28/
Rbob.
I am thinking of upgrading my 88 bin and mask to an 89 bin and mask so I figured I would see what I could find while I am waiting for my ostrich and g1 adapter to come in the mail. I found an ANZA bin and I am not sure if this would be a good choice to start with, my engine is an 88 5.0 lb9 and stick shift and it has 3.08 gears, my computer is a 165, however the ANZA is listed for a firebird with California emissions, but otherwise is a good match. So I was wondering if I could get some input as to weather the ANZA bin would be a good choice as a starting point to tune my car thanks, Adam
Old Feb 7, 2014 | 12:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Choosing a Bin
Since you are tuning it, it doesnt really matter what you start with. Any 5.0 5spd bin would work but need to know if you have the peanut cam lb9 or the l98 cam lb9. Big difference. Match the bin to your model as close as you can with that in mind. g92 cars should all have the big cam. The rest of the bin information you can Edit to match.
Old Feb 7, 2014 | 07:36 PM
Axle/Gears: 3.08
Re: Choosing a Bin
the ANZA bin looks the closest except it is California emissions the two best matches are ANYR and APYX except I cannot find either of them yet, my car has the big cam .415 and .430 lift, I verified this when I measured the cam when I had the motor apart
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
bjpotter
Oct 4, 2015 07:48 PM
Vincent135
Sep 28, 2015 10:50 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
