Maf Raw Input versus Mass Air Flow
Old Feb 21, 2014 | 08:43 PM
ATSAaron's Avatar
Should those two values be basically the same?
Thanks,
Aaron
Old Feb 22, 2014 | 10:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Maf Raw Input versus Mass Air Flow
Thanks,
Aaron
No.
RBob.
Old Feb 22, 2014 | 03:37 PM
tequilaboy's Avatar
In most situations, they should be nearly the same neglecting scaling and resolution differences. The raw input value is the unlimited airflow expressed as an 8 bit value. If the two values differ significantly then the MAF flow value is being limited by the max maf flow vs rpm table.
This commonly occurs with ign on and engine off or during cranking, or when the MAF sensor is unplugged or failed. Can also occur if MAF calibration has been changed or if the actual airflow exceeds the max maf vs rpm table limit.
Old Feb 23, 2014 | 08:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I guess it depends upon the definition of "MAF raw input." To me it is the 0 to 5 volt output of the MAF that is the input to the ECM.
RBob.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
