AUJP and a Manual Transmission?
Old Aug 20, 2014 | 10:00 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi All,
Any thoughts on using the AUJP $8D for a TKO-500 manual transmission application?
AUJP was used and modified during the engine dyno session. Would like to use this modified BIN for initial in car tuning.
Any issues with IAC control?
Best a Regards,
Bruce
Old Aug 20, 2014 | 11:07 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: AUJP and a Manual Transmission?
Its all about the IAC.
S_AUJP V4 could be used with some IAC control tables copied from manual bins.
There are some problems doing it with the stock AUJP (you could try of course)
See the S_AUJP threads for more info.
Jp
Old Aug 20, 2014 | 11:26 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Thanks JP,
I have read through many of the threads, somewhat over my head at this point.
What is the advantage of the S_AUJP over the AUJP from an IAC perspective?
Is the Throttle Follower action the biggest issue with using an Auto BIN in a Manual application?
Just looking to simplify my initial start-up and in-car tuning. Not sure if I need to junp to the S_AUJP first?
What is the disadvantage (wrt S_AUJP) of setting the AUJP transmission type BIT to manual and copying the IAC parameters from an $8D manual transmission bin?
Thanks again for the help.
Best Regards,
Bruce
Old Aug 20, 2014 | 03:46 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
AXCN is a Corvette 350 manual bin and it works in a '7730
The ECM is different but the board inside is the same.
Old Aug 20, 2014 | 04:57 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Thanks Don,
I will take look at that BIN.
By the way, thanks for building my headers.
Best Regards,
Bruce
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
