Newbie to tuning need help
Old Mar 21, 2015 | 01:59 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Hey everyone i been looking in the main sticky in the section and im all confused about it trying to figure out what tuner i should get to tun my 355 hsr build im doing someone told me about the moates g1 adaptor with the ostrich 2.0 setup is this what i need to do the tune i know i also need a laptop and the software which should come with the tuner i buy if im correct
Old Mar 21, 2015 | 03:14 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: Newbie to tuning need help
Since it looks like you have a 5 spd. trans I would go with Fasts EZ EFI basic kit for TPI.Can be had for around $800.It's self tuning and you will save yourself a lot of headaches.
Old Mar 21, 2015 | 03:57 PM
Engine: LR4 4.8
Dang 800.00 bucks is alot of money for a tuning setup im gonna get more info on this to see if i can find a cheaper setup somehow
Old Mar 21, 2015 | 08:54 PM
nossbc's Avatar
Car: 1990 gta
Engine: 383,tfs heads,hsr
Axle/Gears: 12 bolt 3.73
I would look into the ebl p4 flash.
you will not regret it...plus its affordable!
Old Mar 22, 2015 | 08:48 AM
Engine: LR4 4.8
Yea i looked up the elb p4 flash last night looks pretty easy to do im gonna try and talk to a rep about it to see if they can help out the easiest way to tune ill prob buy the ecm already with the elb installed and then just go from there with the tuning
Zell1luk
Sep 29, 2015 10:36 AM
