ebay sensors to datalog with the ebl?
Old May 13, 2015 | 06:50 PM
nossbc's Avatar
Car: 1990 gta
Engine: 383,tfs heads,hsr
Axle/Gears: 12 bolt 3.73
can I use this sensors for my fuel, oil etc to datalog with the ebl p4?
http://www.ebay.com/itm/Pressure-transducer-sender-sensor-200-psi-stainless-steel-for-oil-fuel-air-water-/171412350627?hash=item27e8f8e6a3&vxp=mtr
and if I can how do I wire it and program it to read the sensor?
Old May 13, 2015 | 07:41 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
Re: ebay sensors to datalog with the ebl?
this sensor appears to have a 0-200psi range, with a .5-4.5 volt linear output. Seems to me that you wont have very good resolution at low pressure levels with a 8bit range spread from 0-5v.
On the plus side, the price is nice though, and the sensor is compact and looks like it uses a metripack type connector.
Old May 14, 2015 | 03:44 PM
nossbc's Avatar
Car: 1990 gta
well on further research I found a 80psi sensor from the same guy also a 100psi one and it uses a metripack conector wich is standard with most aftermarket sensors.
how do I connect it?
F.I. 57 Belair
Aug 23, 2021 01:09 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
e3pres
Sep 9, 2015 01:51 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
85Special
Sep 3, 2015 04:21 PM
