Spark Vs AFR Table
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Spark Vs AFR Table
I was looking for help with this on another thread but I didn't get responses so I figured I'd create another around this. I'm trying to add a simple 8X1 table that adds spark based on the commanded AFR to my modified version of $6E. For some reason the code I wrote doesn't work. I've tried various code changes but nothing seemed to help. I output the converted AFR value in a datalog to see if it was actually doing anything and it just gives me a blank (00) value, so either the code isn't being run for some reason or I must not be handling the AFR value (L00D5) properly. All the start up spark code has been removed. This is what I wrote.
CE FF FF DC D5 02 C1 B8 23 02 86 B8 C6 48 CE C1 9D BD F3 F2 97 12
; Lk Up Spark vs Commanded AFR Tbl
F853: LDX #65535 ; LOAD 16B TO 8B CONV #
F856: LDD L00D5 ; COMMANDED AFR
F858: IDIV ; CONV TO TABLE UNITS
F859: CMPB #184 ; COMP TO MAX AFR FOR LK UP
F85B: BLS LF85F ; BR IF AFR LOWER
; ... else
F85D: LDAA #184 ; Force MAX AFR FOR LOOK UP
F85F: LDAB #72 ; MIN AFR FOR LK UP
F861: LDX #$C19D ; INDEX HWY MODE SPARK TBL
F864: JSR LF3F2 ; 2D lk up, W/MIN VAL
F867: STAA L0012 ; SAVE AFR SPARK ADVANCE
; ... else
Car: check
Engine: check
Transmission: check
Re: Spark Vs AFR Table
There is a simple error in the high limit check. You are testing reg B, but then load reg A if the value is too high. Then reg B gets the table low offset parameter.
To go from the internal FAR value to an AFR value, need to reconstruct the IDIV. Note how IDIV works:
Operation: (ACCD)/(IX); IX: Quotient, ACCD: Remainder
LDD #65535 ; conversion constant
LDX L00D5 ; COMMANDED FAR
At this point the LSB of IX holds the AFR (times 10).
RBob.
RBob.
Car: '85 maro
Didn't notice that, thanks
. Any idea as to why it returns 00 when I output it to datalog after the IDIV operation?
Edit- I may have answered my own question. Testing...
. Any idea as to why it returns 00 when I output it to datalog after the IDIV operation?Edit- I may have answered my own question. Testing...
HoosierinWA
Oct 7, 2015 10:15 AM
