Coil Parameters for a BIN?
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
Does anyone have any knowledge on how the coil dwell time is set up in the popular bins ($32B & $8D)?
Just thinking back to the old days when I set up the points for a specific coil.
Best Regards,
Bruce
Best Regards,
Bruce
Car: check
Engine: check
Transmission: check
Re: Coil Parameters for a BIN?
The GM coil dwell code is rather sophisticated. For static dwell it is a three line slope that is based on RPM. There is then dynamic dwell and battery compensation.
The dwell can also be limited to ensure a 600 usec minimum burn time.
The dwell parameters are hard coded, but can always hex edit the BIN to change them.
RBob.
RBob.
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
