Datalogging data - Am I good?
Old Jun 22, 2016 | 10:56 AM
killer777's Avatar
Car: 1989 Firebird Trans Am
Engine: 355
Wanted to make sure everything was mechanically sound before I start the tuning process. EST error code popped up. Runs alright, can start a little hard, but it runs fine. EST I would imagine would make it run like straight crap considering it controls timing adv./curve.
Also, I'm not sure what the spec on these O2 sensors are, and wouldn't be able to find out until the weekend when I can get on all data or mitchell. Based on temperature, is this what it should be reading?
-Alex
Old Jun 22, 2016 | 09:24 PM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
Re: Datalogging data - Am I good?
It will still run with an EST error the module will have some rudimentary control of timing. That is definitely a big problem though, You need to fix it before proceeding with any tuning.
Old Jun 23, 2016 | 03:43 PM
killer777's Avatar
Engine: 355
Alright, I will find if I have a bad wiring issue or if the EST is bad and will replace it when I get the chance. However, did you have any idea if the other readings were correct for temperature?
Old Jun 26, 2016 | 12:52 AM
MaxpowerTA's Avatar
Axle/Gears: 4.11
Everything else looks pretty normal
Dartht33bagger
30
Aug 14, 2018 03:43 PM
chazman
Third Gen Expo
Jun 3, 2016 10:32 AM
jjjosh
Apr 7, 2016 10:38 AM
Dewey316
Apr 25, 2001 04:55 PM
