Vacuum Reference on TPI Regulator
Old Aug 16, 2016 | 01:40 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Just wondering what everyone's thoughts were on whether or not to run a vacuum line to my holley AFPR on my TPI intake.
I was reviewing some logs and noticing some small (5-ish) flucutations in fuel pressure even at WOT. I have a 100psi fuel pressure transducer hooked to the rail to monitor the pressure.
I also noted some small differences in the WOT AFR that seem directly related to the fluctuations in fuel pressure.
I'm looking for the most consistent AFR possible. I know that disconnecting the vac line from the regulator would require modifying the VE tables but I was just wondering whether or not it would produce any real differences in the end, especially taking cam specs into consideration which directly affect vacuum.
instaldave
Apr 7, 2016 06:14 AM
thomashearts
Carburetors
Apr 3, 2016 08:28 PM
tcrisp
Apr 2, 2016 08:55 PM
edwardk12687
Carburetors
Mar 17, 2016 03:43 PM
Superblue87Formula
Aftermarket Product Review
Nov 21, 2000 09:56 AM
