can't burn '512 chip in tuner pro rt
Old Aug 16, 2016 | 10:06 PM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
okay so I got my car dyno tuned the other and it runs fantastic but I can't get the chip to burn correctly I am using the correct hex stuff but when I throw the chip in the ecu it "runs" off stock tune (limp mode). I am using the moates apu1 with tuner pro RT, I have verified the chips are blank and even verify that it matches the buffer after it is burnt. the chip in the burner is away from the handle with the notch facing the handle and when I put in the ecu the notch faces toward the ZIF handle. am I over looking something? I burnt chips before and they have worked. I gave up and just left my computer hooked up emulating to get it home.
Old Aug 16, 2016 | 10:33 PM
nuggie's Avatar
Re: can't burn '512 chip in tuner pro rt
okay so when I load the file to buffer and click edit it shows nothing but 0's for the whole table. Is it that I am not uploading the file to the buffer correctly?
Old Aug 16, 2016 | 10:50 PM
nuggie's Avatar
okay I am stupid looks like I had to files saved with today's date one was blank and one saved in the wrong folder (auto save folder) was what I need
Old Aug 17, 2016 | 07:52 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
What adapter are you using in the ECM? If it's the GP1 (http://www.moates.net/gp1-package-gm...ips-pi-41.html) with the ZIF socket, the chip notch (pin 1) faces AWAY from the lever.
I_R_O_C_Z_2_8
56
Apr 1, 2016 10:15 AM
theformula
Aftermarket Product Review
Mar 6, 2001 11:25 AM
99MONGOOSE
Feb 23, 2001 05:30 PM
theformula
Nov 15, 2000 05:17 PM
Snomadnes
Oct 5, 2000 01:03 PM
