EGR disable add fuel?
Old Feb 12, 2017 | 01:20 PM
IroczInOz's Avatar
For the people who have deleted their EGR on MAF cars have you added a little bit of fuel to help with combating the higher temperatures or is this a null point?
Old Feb 12, 2017 | 02:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EGR disable add fuel?
I've never worried about slightly higher combustion chamber temperature with removing egr function. Or are you referring to lean cruise and egr ?
Old Feb 12, 2017 | 02:53 PM
IroczInOz's Avatar
yeah cruising at speed with non working egr concern?
Old Feb 12, 2017 | 03:06 PM
Engine: Lb9
Transmission: M20
Higher cylinder temperature can lead to pre-det.
But there are tons of pre 70s engine and race eng not using egr system.
I have my egr disabled and don't get any knock. With the egr disabled the timing
Will not advance for egr operation.
Old Feb 12, 2017 | 04:21 PM
IroczInOz's Avatar
perfect thanks for the info. Sounds like disable egr and not worry about it.
Old Feb 12, 2017 | 08:40 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My Express van has had the EGR turned off and removed for several years. Removed it when the Marine intake went on. I run lean cruise on it at about 15.5-16:1 afr. Have not had any issues from running lean without EGR.
Old Feb 13, 2017 | 12:33 AM
IroczInOz's Avatar
That is good to hear all good then. Sounds like no need to worry about it.
