DA data error in Tunerpro v5
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
I've tried the listen for silence command and tinkering with the com port latency rates.
I'm at a loss. Someone willing to help me?
165 ecm $6e definition.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: DA data error in Tunerpro v5
You might have to try another adx or ecm.
http://www.gearhead-efi.com/Fuel-Injection/showthread.php?366-1227165-ECM-Information-6E
Car: 1987 IROC Z28
Ok so I went into the port settings and raised the minimum read/ write timeout period to 900ms.
i have left the "listen for silence" command I the definition alone at 20ms.
No more bad data error and just says "connected". So I'm in the right direction.
But the data I'm getting is clearly incorrect. Help?
Car: 1987 IROC Z28
I actually went up and up until it stopped. But the data is still bad.
Engine: Lb9
Transmission: M20
The setting listed here might help, not sure about the bogus information .
https://www.thirdgen.org/forums/diy-...ror-every.html
