EBL Manual LT4 Hotcam to Automatic Tune
Old Aug 16, 2017 | 10:26 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
I have an opportunity to get a used TPI engine with an LT4 Hotcam for a decent price. It was being run on EBL with a manual transmission, but I have an automatic. What are my options as far as getting a proper tune on it. I haven't done any tuning apart from cold start tuning. Maybe someone has already done an LT4 hotcam tune for automatic that I can start from?
Also would it be a good upgrade from my stock 350? It's got stock TPI intake, LT4 Hotcam with 1.6 rockers, and Corvette aluminum heads. Already have plenty of exhaust sizing to support it. Was thinking about getting another engine so I can start working on a 383 FIRST build so this might fit the bill if I can get it swapped in and running pretty good in a short period.
Old Aug 17, 2017 | 08:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL Manual LT4 Hotcam to Automatic Tune
Set the TCC option flag. Then dial in the lower RPM SA so that the engine/vehicle drives OK. That is at idle, off-idle and low throttle inputs.
For a throttle stomp from a standstill can use the launch mode (LM) parameters to get the engine up against the convertor.
Can also change the TCC lockup/unlock for how you like it.
RBob.
Old Aug 17, 2017 | 10:28 AM
someone972's Avatar
Engine: 5.7L TPI
Does EBL use the same BIN for both manual and automatic cars? I would certainly feel more confident if I had an automatic tune for an engine close to the one I'm considering.
Old Aug 17, 2017 | 10:52 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
It comes with a variety of bins, just pick the L98 bin and make a few changes to accommodate your injectors (if different), cam and increased air flow. Easy peasy...
