Extreme lean condition caused by bad tune?
Old Sep 25, 2017 | 11:51 PM
broke91firebird's Avatar
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
I'm working on a 3.1v6 and 7730 ecu swapped 86 Camaro. I've been fighting for a while now(before the swaps) a high idle where the car will idle around 1100 at start up then the idle climb to 2000-2500 after you start driving.
The IAC is new and the passages are clean. Tonight I noticed the headers glowing a dull orange after about an hour drive. At idle (170ish coolant temp) cylinder 1 was about 350° while the rest were 450° to 500°.
At 1000rpm idle vacuum is almost exactly 20 in and fuel pressure is 43 psi with key on engine off. All injectors ohm 12.9-13.1
could this be a tuning issue or something mechanical going bad?
Old Sep 26, 2017 | 12:38 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: Extreme lean condition caused by bad tune?
Yes
Old Sep 26, 2017 | 06:35 AM
Originally Posted by Vanilla Ice
Yes
Ant idea on which, or where to start looking?
My list of possible issues shrinks every time I work on the car.
Old Sep 26, 2017 | 09:31 AM
Engine: LB9
Axle/Gears: 3.08
Gm put out a product that works. What's different on your car?
What's been changed recently?
Start answering those questions and that's where you look first.
Old Sep 28, 2017 | 01:41 PM
The problem is that the answer to your question is "almost everything" it last ran well before the '302 ecm died( 9mpg no idle no ALDL communication) since then, the ecm, intake, timing, and tune have been changed.
