BOSCH III 0280155710 Voltage Offsets
Car: 1987 Fiero GT
Transmission: 5 speed Getrag
I have some BOSCH 0280155710 injectors and it appears from research they are very close in size to the 028155700 so the size is not a concern but the voltage offset is as I cannot find the voltage offset for this injector.
I did find this thread but nothing conclusive to what the offsets are: https://www.thirdgen.org/forums/diy-...155-710-a.html
Does anyone have this information?
Thank You
Thank You
Re: BOSCH III 0280155710 Voltage Offsets
Car: 1987 Fiero GT
I did see this thread but it just lists the offsets for the 0280155700 and not the 0280155710. They seem to be very similar so I can start with these offsets.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
So here is some info on the bosch 280155700's. Hope this helps. They are rated
19lb at Ford pressure and 22lb at GM pressure:
Bosch EV6 19 lb/hr @ 39.15psi
0-280-155-700 / 710
Low Slope 23.76
High Slope 19.26
Breakpoint 0.00001
VOLTAGE OFFSET
voltage ms
16.00 0.78
15.00 0.78
14.00 0.78
13.00 0.936
12.00 1.093
11.00 1.25
10.00 1.47
0-280-155-700 / 710
Low Slope 23.76
High Slope 19.26
Breakpoint 0.00001
VOLTAGE OFFSET
voltage ms
16.00 0.78
15.00 0.78
14.00 0.78
13.00 0.936
12.00 1.093
11.00 1.25
10.00 1.47
Car: 1987 Fiero GT
Great! Thanks Tuned Performance I did read through that thread before I got the injectors but it did not show up in searching because the part number was not complete.
Car: 1987 Fiero GT
What is the best way to fill in all the fields for offsets? I see interpolation based off the offsets you have using the XDF file I am using I have the below to fill in:
Is there a better XDF file to use? Does anyone have these already for these injectors? If not what is the best way to do interpolation?
I will be installing these injectors tomorrow.
also note that the values provided by south bay are in milliseconds. you need to input them in microseconds.
simply multiply south bays values by 1000 prior to using them.
Car: 1987 Fiero GT
OK thank you. I came up with this:
VDC = uS
1.6 = 2714.47
3.2 = 2464.86
4.8 = 2215.25
6.4 = 1965.64
8.0 = 1716.03
9.6 = 1466.42
12.8 = 967.2
14.4 = 717.6
16.0 = 467.99
17.6 = 218.38
19.2 = -31.23
VDC = uS
1.6 = 2714.47
3.2 = 2464.86
4.8 = 2215.25
6.4 = 1965.64
8.0 = 1716.03
9.6 = 1466.42
12.8 = 967.2
14.4 = 717.6
16.0 = 467.99
17.6 = 218.38
19.2 = -31.23
strange that their values stay constant above 14V... seems like typically there's always variation with voltage...
Earlier post from RBob on that other thread...
Originally Posted by RBob
From what I've found on the 'net the 280-155-700 injector is a 19#/hr. But that is with a substitute liquid (not gasoline).
I'm not sure if I used the correct data sheet. As the 280-155-700 is a Bosch number which Ford doesn't use. I used the Ford 19 #/hr data.
With that here is the data for the injector at 44 psi, values in mSec:
6.4 V: 3.07851247
8.0 V: 1.85340073
9.6 V: 1.30766195
11.2 V: 0.99121428
12.8 V: 0.76537403
14.4 V: 0.60906068
15.0 V: 0.55248610*
Can round as required and extrapolate from the 14.4 V and 15 V for the 16 V entry.
Minimum PW is: 0.853 mSec
RBob.
From what I've found on the 'net the 280-155-700 injector is a 19#/hr. But that is with a substitute liquid (not gasoline).I'm not sure if I used the correct data sheet. As the 280-155-700 is a Bosch number which Ford doesn't use. I used the Ford 19 #/hr data.
6.4 V: 3.07851247
8.0 V: 1.85340073
9.6 V: 1.30766195
11.2 V: 0.99121428
12.8 V: 0.76537403
14.4 V: 0.60906068
15.0 V: 0.55248610*
RBob.
Car: 1987 Fiero GT
I thought it was strange also so I started with 13 and 12 volts to start the interpolation. I found this calculator: https://www.shodor.org/os411/courses...ion/index.html
Car: 1987 Fiero GT
I am now running S_AUJP V5 bin and the XDF does not show the same table as I posted above and doing a search for injector, offset, or correction does not find this table. I copied the old bin that had this over to this one that had this.
I am on the road now with the car and warm start has extended cranking time and it seems like opening the throttle helps any idea what I can change? I brought everything with to make changes.
Thank You
Thank You
