What bin is $6E aujm?
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
Like the title says, just curious, i found it on . .
forgot the site, its where you find all the bins.
Re: What bin is $6E aujm?
And whats the difference between this and the apym.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Aujm is for a 89 5.7l automatic 3.27 rear gears, apym is for 2.73,2.77 ratio gears. You can do a file compare with tuner pro rt. Sa, maf tables, stall saver , ect are different.
Why would there be a difference because of gearing?
Engine: Lb9
Transmission: M20
Emissions and different sa to help get the vehicle moving
Car: check
Engine: check
Transmission: check
AUJM was released in early '90, so it probably has some drive-ability fixes in it. Should make a good starting point for further tuning.
APYM is for a LB9 5.0l engine.
RBob.
RBob.
87TPI-5SPD-TA
Oct 21, 2011 06:39 PM
