IAC Tuner Pro Reading's At Start
Old Jul 18, 2019 | 08:18 AM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
Having trouble with start and idle on a newly built motor install. Turns over but won't start unless you step on the gas and the it idles very high, without changing rpm's even if you continue to give it gas. So.... logging from TunerProRT, I"m showing the IAC as follow...
IAC Motor Postion - 160
IAC Command Direction - 128
These do not change from just key on, to trying to start, should either of them?
Thank you!
Old Jul 27, 2019 | 11:25 AM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Re: IAC Tuner Pro Reading's At Start
Thank you!
Not sure about direction, but IAC should drop immediately when engine begins running to what the code believes the proper IAC position to be (+20 steps if AC is on). A direction value of 128 means no movement is requested. I believe < 128 = IAC is retracting/opening; > 128 = extending/closing. But if no movement, seems like IAC not properly communicating with ECM (wiring connections, etc. )
JeepYJv8
16
Nov 7, 2010 10:04 PM
boldguy
Mar 4, 2009 04:41 PM
jsup
Feb 1, 2009 11:54 AM
epsmotorsports
Apr 23, 2008 07:36 AM
adambros
Jul 7, 2004 05:28 PM
